PPS
PPS
How to change line color in CDF or Quantile plot?
I am generating cummulative plots like the example below.
However, I want to color of the lines not to be determined by col2 but by col3.
Adding Color ( :col3 ) didn't do the trick...
Thx, Phil
Oneway(
Y( :col1), X( :col2),
All Graphs( 0 ), Plot Quantile by Actual( 1 ), Line of Fit( 0 ), X Axis Proportional( 0 ), Grand Mean( 0 ), Color ( :col3 )
Re: How to change line color in CDF or Quantile plot?
I can understand how you could color data points by a different column
dt = Open( "$SAMPLE_DATA\big class.jmp" );
dt << Oneway(
	Y( :weight ),
	X( :sex ),
	All Graphs( 0 ),
	Line of Fit( 0(1) ),
	Grand Mean( 0 )
dt << color by( :age );
but I don't see how you directly do it with the line segments, since each segment is linked between 2 values that may have 2 different values of the 3rd color.   Could you provide a mockup of what you are thinking?
PPS
PPS
Thx a lot for the swift response.
Attached is an example with several classes M/F. Each class has its line
but colors defined by sex.
Icing on the cake would be color by sex and dash type by class :)
Philipp
Oneway(
Y( :Weight ),
X( :Sex_Class),
Proportional( 0 ), Grand Mean( 0 ), Color ( :sex ),
Dispatch( {"Normal Quantile Plot"}, "Oneway QuantilePlot", FrameBox, {Line
Width Scale( 3 ), Transparency( 0 )} ),
You can achieve what you want by setting the Value Colors you want for the :Sex_Class column you are working with.  Here is the JSL to do it, but it can easily be done interactively
// Create a new column
dt << new column("Sex_Class", character,
	formula(:Sex || "_" || char(:Age))
// Determine how many groups in the :Sex_Class
summarize(dt,groups=by(:Sex_Class));
// Create the value colors list
colorlist={};
For(i=1,i<=n items(groups),i++,
	If(substr(groups[i],1,1)=="F",
		color=19,
		color=21
	Eval(
		Substitute(
			Expr(
				insert into(colorlist, __group__  )),
				expr( __group__ ), parse("{\!""||groups[i]||"\!""||"="||char(color)||"}")
// Set the Value Colors property for the Sex_Class column
dt:sex_CLASS<<set property("value colors",eval(colorlist));
dt << Oneway(
	Y( :weight ),
	X( :sex_class ),
	All Graphs( 0 ),
	Grand Mean( 0 )
PPS
PPS
Wow! I'm impressed! It works! I have modified the script to accommodate for
the case of more than 2 colors:
// Determine colors for lots
summarize(dt,groups=by(:sex_class));
colorlist={}; color=3; Sxcnt=Word(1,groups[1],"_");
For(j=1,j<=n items(groups),j++,
If(Not(Word(1,groups[j],"_")==Sxcnt),color=color+1;Sxcnt=Word(1,groups[j],"_"));
Eval(Substitute(Expr(insert into(colorlist, __group__ )), expr( __group__
), parse("{\!""||groups[j]||"\!""||"="||char(color)||"}") ) );
dt:sex_class<
Thanks a lot, but now I got greedy. What about changing dash style by class?
Thanks, Philipp
Try this on for size
dt << New Column( "Sex_Class", character, formula( :Sex || "_" || Char( :Age ) ) );
Summarize( dt, groups = by( :Sex_Class ) );
colorlist = {};
For( i = 1, i <= N Items( groups ), i++,
	If( Substr( groups[i], 1, 1 ) == "F",
		color = 19,
		color = 21
	Eval(
		Substitute(
				Expr(
					Insert Into( colorlist, __group__ )
			Expr( __group__ ), Parse( "{\!"" || groups[i] || "\!"" || "=" || Char( color ) || "}" )
dt:sex_CLASS << set property( "value colors", Eval( colorlist ) );
linetype = {"Solid", "Dotted", "DashDot", "DashDotDot", "Dashed"};
TheExpr =
"Oneway(
	Y( :weight ),
	X( :Sex_Class ),
	All Graphs( 0 ),
	Line of Fit( 0 ),
	Grand Mean( 0 ),
		Dispatch(
			\!"222\!",
			ScaleBox,
			{Legend Model(
				1,";
	If( i > 1,
		TheExpr = TheExpr || ","
	TheExpr = TheExpr || "Properties(" || Char( i ) || ", {Line Style(\!"" || linetype[Mod( i, 5 ) + 1] || "\!" )} )";
TheExpr = TheExpr || "),
Eval( Parse( theexpr ) );
There are only 5 line styles available
PPS
PPS
Thanks again for your efforts.
I believe there were a few syntax errors in your script suggestion, which I
fixed. See below. However, I keep getting error messages like "Cannot find
ScaleBox[ "400" ] at {}", even if I go with "222" as you suggested. (BTW,
never understood what that number means) And the line styles are not
adjusted. Colors work ok as before.
thanks, Philipp
Expr =
"Oneway(
Y( :weight ),
X( :Sex_Class ),
All Graphs( 0 ),
Line of Fit( 0 ),
Grand Mean( 0 ),
Dispatch({},\!"400\!",
ScaleBox,
{Legend Model(1";
Expr = Expr || ",Properties(" || Char( i ) || ", {Line Style(\!"" ||
Expr = Expr || ")})))";
Eval( Parse( Expr ) );
