I'd like to create a window selecting parameters from differents tables. I use journal and scripts for this.
The best I can do for this, is opening a new window for each table.
choix1 =Column Dialog(
current data table(dt_fil_step_1);
selection_step_1 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_1)) ),
current data table(dt_fil_step_2);
selection_step_2 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_2) ) ),
current data table(dt_fil_step_3);
selection_step_3 = colList( "Paramètres à représenter", maxcol( N Col(dt_fil_step_3) ) );
Actually the window should look like this :
To start with, you do not want to use a Column Dialog(). That methodology is being de-emphasized in JMP. Below is the beginning of a script that will do what you want. You will need to fill in the code you need to populate the Parameters Selected list, etc. but it does popup the 3 data tables for you to select from.
dt_fil_step_1 = Open( "$SAMPLE_DATA/big class.jmp" );
dt_fil_step_2 = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
dt_fil_step_3 = Open( "$SAMPLE_DATA/drug measurements.jmp" );
selected list = {};
choix1 = New Window( "test",
Lineup Box( N Col( 2 ),
Current Data Table( dt_fil_step_1 );
selection_step_1 = Col List Box( dt_fil_step_1, all );,
step_1_BB = Button Box( "Select for Data Table 1" ),
Current Data Table( dt_fil_step_2 );
selection_step_2 = Col List Box( dt_fil_step_2, all );,
step_2_BB = Button Box( "Select for Data Table 2" ),
Current Data Table( dt_fil_step_3 );
selection_step_3 = Col List Box( dt_fil_step_3, all );,
step_3_BB = Button Box( "Select for Data Table 3" )
selected list = List Box( selected list, nlines( 22 ) )
The ButtonBoxes would then need their click action defined, for example:
step_1_BB <<Script(selected list << Append( selection_step_1 << GetSelected ));
Thanks a lot it's running well.
