tajrida
How to add percentile lines in probability plot?
example: suppose I want to mark the 90th percentile on Y axis and link it to its corresponding value on x-axis on a probability plot.
How can this  be done? Thanks
Mohammed Ahmed
Re: How to add percentile lines in probability plot?
See Help > Books > Essential Graphing for more details.
You can use the Line and Annotation tools to add these graphic elements to your plot with the mouse.
Alternatively, you can right-click inside the plot frame and select Customize. You will have to add some scripting expressions. The Pen Color( "red" ), H Line( x min, x max, 90 ), V Line( quantile, y min, y max ), and Text( CounterClockwise, "quantile" ) would be all you need.
The answer depends on many things. For example,
  • Do you want to work interactively or use a script?
  • Are you using a built-in plot (e.g., Normal Quantile Plot in Distribution) or a custom plot (e.g., Picture Box object)?
  • How do you want to mark the 90th percentile? A line?
  • How is the percentile determined? Is it the empirical distribution, such as used in Quantiles report from Distribution? Is it from a fitted distribution model?
tajrida
1. I work interactively 100%
2. Using a built in plot (e.g., Normal Quantile Plot in Distribution)
3. A line (L - shaped) going from 90th percentile on Y axis and connecting to corresponding value on X axis
4. The percentile is choosen
Please see attached JPG for reference.. thanks
Probability Plot of Cycle Time (days).jpgProbability Plot of Cycle Time (days).jpg
Mohammed Ahmed
What if you need to draw a line for each categorical value you have in the X AXIS? The customized scripting does not work that way. Additionally the bar or line drop down menu (red triangle) doesn't include an option for the summary statistic to be a quantile.
M. Dereviankin
