patriciafm811
How do I get labels to 'stack' in graph builder?
Hello. I am trying to get the labels in this map to be 'stacked' (so that it says the abbreviation on one line and then the number on the next line). Is there a way to do this? Thank you!
Re: How do I get labels to 'stack' in graph builder?
I think one fairly easy option which should work is to create new column with ",\!N" as separator between different values.
:name << Label(0);
new_col = dt << New Column("LABEL", Character, Nominal, Formula(
	Char(:height) ||",\!N" || Char(:weight)
new_col << Label(1);
gb = dt << Graph Builder(
	Size(1029, 499),
	Variables(X(:name), Y(:height)),
	Elements(Bar(X, Y, Legend(6), Label("Label by Row")))
patriciafm811
So I tried this and I can't get it to work in the map.
Seems to work here
dt = Open("$SAMPLE_DATA/CrimeData.jmp");
dt << New Column("LABEL", Character, Nominal, Label(1), Formula(
	:Region || ",\!N" || :State
:Region << Label(0);
:State << Label(0);
:Year << Label(0);
dt << Select Where(Row() != Col Min(Row(), :State)) << Hide and Exclude(1);
dt << Select Where(Row() == Col Min(Row(), :State)) << Label << Clear Select;
	Variables(Color(:Total Rate), Shape(:State)),
	Elements(Map Shapes())
Do you happen to have multiple values for each map shape?
patriciafm811
I can't seem to get it.
You have to use label only on the formula column. And I'm not sure if you can write row change to the column by hand (that is why I did use formula with concatenation). You can see that the "\!N" is not visible in my rows
(I'm using JMP17)
