How can I fix the seeds of the clusters in the normal mixtures clustering method so that it gives a fixed result every time it is run?
Mar 14, 2024 03:39 AM(1694 views)
Hi there, I want to use normal mixtures method to cluster my data, but it gives a different result every time it is run. Does anyone know how I can fix the seeds of the clusters?
