SinemYu
ROC curve column
I am able to generate the ROC curves as I want, but somehow I cannot show the columns (covariates) on side of the graph. I wanted to list the covariates I used to predict the category and was able to do so but now I guess I cannot bring it back. How can I add the columns info like below?
 THANK YOU!
SDF1
Re: ROC curve column
Hi @SinemYu ,
  Welcome to the community!
  For your particular problem at hand, can you provide a little more context, or a sample data table (anonymized, perhaps if there is sensitive data), so that others can follow the steps you've taken in order to recreate the issue you're having. It's hard to understand exactly what you're trying to do and how a problem is arising based on the description you gave.
Thanks!,
DS
