Hi @ZHANDOUJI,
As explained by @statman, Stepwise method is not a default model building method recommended with DOE data, as you already have assumed a model that guide your experimentation and data collection strategies. You're not a in a situation where the data collection is imposed to you, and you have to "figure out"/determine a possible likely model for this data.
Starting with your assumed model with the simple Least Squares method should be a good starting point.
You can check the "Fit separately" option.
In order to refine your model (based on p-values, R² and R² adjusted, RMSE, and/or Information criterion like AICc), you can then for each of your response remove the least important/active terms from your model :
You can read more about model building and selection in other related discussions :
Statistical Significance
best model
Analysis of split plot design with full factorial vs RSM
Fit Definitive Screening vs. Stepwise (min. AICC) for model selection
Victor GUILLER
