Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Created:
Jun 15, 2020 02:23 PM
| Last Modified: Jun 11, 2023 4:02 AM(5527 views)
Hi JMP Community,
In Graph Builder, is it possible to modify the origin of the bars in a Bar graph so that the all bars start at the lowest value of Y instead of starting at 0?
Make a new column with the minimum value. Drag this column along with the original data column to the Y drop zone. Drag the categorical column to the X drop zone. Change the bar type to Range in the properties list.
Thanks for your reply but this is not what I'm looking for (sorry if I was not clear). I know how to change the Y Axis scale but I don't know how to change the origin/base of the bars in a bar graph. By default, all the bars have an origin set to 0 and the bars have opposite directions depending on whether the data is positive or negative: is it possible to change the bar behavior so that all bars "start" at the lowest value of the data range? Thanks, TS
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '272758' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '272758') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '272758') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
