Thierry_S
Graph Builder > Bar Graph > Change Y Axis Origin?
Hi JMP Community,
In Graph Builder, is it possible to modify the origin of the bars in a Bar graph so that the all bars start at the lowest value of Y instead of starting at 0?
Thanks for your help.
Best,
TS
Thierry R. Sornasse
Re: Graph Builder > Bar Graph > Change Y Axis Origin?
Make a new column with the minimum value. Drag this column along with the original data column to the Y drop zone. Drag the categorical column to the X drop zone. Change the bar type to Range in the properties list.
Yes, you can change the minimum of a bar chart in graph builder.
Double-click the axis and specify the new minimum.
Dan Obermiller
Thierry_S
Hi Dan,
Thanks for your reply but this is not what I'm looking for (sorry if I was not clear). I know how to change the Y Axis scale but I don't know how to change the origin/base of the bars in a bar graph. By default, all the bars have an origin set to 0 and the bars have opposite directions depending on whether the data is positive or negative: is it possible to change the bar behavior so that all bars "start" at the lowest value of the data range?
Thanks,
TS
Thierry R. Sornasse
