Martin
Graph Builder Y-axis custom scale to 1x10^n
I am trying to set the y-axis on a graph builder (which spans several logs) to a major axis of "1x10n" where the n is a superscript.  I want it to look like the attached picture.
Is there a way to do this? If so, how?
Thank you!
Re: Graph Builder Y-axis custom scale to 1x10^n
That was created using the script below, with the max value of the Y axis set using your formula, with your n value set to 7
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
gb = dt << Graph Builder(
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 6 ) ), Smoother( X, Y, Legend( 7 ) ) ),
		Dispatch(
			"height",
			ScaleBox,
			{Scale( "Log" ), Format( "Best", 6 ), Min( 48.2580966150752 ),
			Max( 71.2073042511286 ), Inc( 1 ), Minor Ticks( 1 )}
report(gb)[AxisBox(2)] << max (1*10^7);
Martin
Thanks Jim, but I specifically want the formal of "1x10" with the log number superscripted, just like the graphic I posted.
ah......my misinterpretation
