I'm sorry for the delay in my response here.
The first thing I notice is that your Method and Mix columns are confounded. That is, Method A only has Mix X and Y, and Method B has only Mix Y and Z. So, if your real data looks like this there is no point in including both Mix and Method.
After running Fit Model with only Mix and Conc. in the model you'll see a profiler like this.
From the red triangle next to Prediction Profiler you can choose Desirability Functions.
That will add a panel on the right side of the Profiler. You can double click on that panel and set the desirability values to match your target of 1.
Once you've done that you can use the option to Maximize Desirability to find a Mix and Conc. that will get get you to your desired response.
Next, if you Ctrl-click in the Mix graph you'll get a dialog where you can lock Mix.
Once the factor is locked the Maximize Desirability option will not change Mix. So, you'll get a Conc. for whatever level of Mix you've chosen. You can change Mix and do that again for another Mix level.
Finally, once the factor is locked you can choose Maximize for Each Grid Point.
This will automatically maximize for each level of Mix.
If you really want to include Icon you can do the same with a model with Mix and Icon. Lock them both in the Profiler and then Maximize for Each Grid Point will create a grid of all combinations of Icon and Mix (beware: that's more than 450 combinations in your sample).
I hope that helps. Keep the questions coming.
-Jeff
