Neo
Neo
How to use use 'not equal to' with logical or
In an if statement I would like to do if myParameter is not equal to either Parameter1 or Parameter2 then return something.  But my following function is not working as expected.,. Where am I going wrong
myFunc =  function ({myParameter}, {default local},
    If (myParameter != Or("Parameter1","Parameter2"),
        return(Eval Insert("output some msg")),
clear log ();
//output = myFunc ("Parameter1");
output = myFunc ("notParameter1");
When it's too good to be true, it's neither
Re: How to use use 'not equal to' with logical or
If you want to use Or the comparison will get very long and annoying to maintain if the allowed parameter list increases. So I would use !Contains and list of allowed parameters (or associative array):
myFunc = Function({myParameter},
	{default local},
	ok_parameters = {"Parameter1", "Parameter2"};
	If(!Contains(ok_parameters, myParameter),
		Return(Eval Insert("^myParameter^ not in list ^ok_parameters^"));
		Return(Eval Insert("^myParameter^ in list ^ok_parameters^"));
output = myFunc("Parameter1");
Show(output);
output = myFunc("notParameter1");
Show(output);
But you can use or/and also, below is one example (| means or):
	{default local},
	If(!(myParameter == "Parameter1" | myParameter == "Parameter2"),
        return(Eval Insert("output some msg"));
show(output);
show(output);
Craige_Hales
You probably mean this (which I like the best)
if ( (myParameter != Parameter1) & (myParameter != Parameter2) , ...
which is the same as this
if( ! ( (myParameter == Parameter1) | (myParameter == Parameter2) ), ...
or, the way you were using the or() function, the same as this
if( !or(myParameter==Parameter1, myParameter==Parameter2), ...
https://en.wikipedia.org/wiki/De_Morgan%27s_laws
Also, if there are missing values, be sure to handle them with isMissing() because they don't compare like you might expect.
Craige
	{default local},
Show(output);
Show(output);
	{default local},
show(output);
show(output);
SDF1
Hi @Neo ,
  I think the problem might be in how your calling the "or" logical operator. In JSL, the logical or is this character | . So, you'd change the If() statement to something like the following it should work:
MyFunc = Function( {Myparam},
	If(
		(Myparam != parm1 | Myparam != parm2), Return( Eval Insert( "Output some msg" ) )
Keep in mind the logical only requires one of those two to be true and it will return the result. If Myparam equals one of those, then it still will return the message.
Hope this helps!,
DS
