I am using the Multichain Monte Carlo, MCMC, add-in in JMP. It is a highly useful program. I am using it to predict probabilities of genes with groups. So I add to parameters, the genes, and run the program. Then I add the groups. I can then construct group probabilities from the profile sliders within the genes. It works great.
Unfortunately, it often throws an error message and the database appears corrupted as I cannot close out and reuse that database. Fortunately, I have copies of the database, which I can go back to.
The error message reads: Need matrix or list argument in access or evaluation of sort ascending, sort ascending/"###"/hpcol/
Does anyone know what this means ? So that I can correct the issue and, hopefully, stop going back to database copies.
Appreciate prior forum responses. Very helpful.
Thanks, Neal
I'm assuming it's this add-in. In which case, it's probably best to contact Richard directly and he can investigate further.
