I'm working with a tabulate box, and I can't delete a column from script.
I have try this :
tab << modify table(column table( 1 ),delete( analysis column( Eval(columns[i]) ) ));
But doesn't work.
Incredibly, this working fine :
tab << modify table(column table(1), delete(analysis columns(:Name("NH3(ppbv)")))
How can I resolve this problem?
Thank you per advance for answers,
Sincerely,
Romain
The Analysis Columns() argument appears not to be evaluated at runtime and thus need to be evaluated ahead.
Two approaches that should work:
// Modify an expression before evaluation
Eval(Eval Expr(tab << modify table(column table(1), delete(analysis column(Expr(columns[i]))))));
// Modify a string before and parsing and evaluation
Eval(Parse(Eval Insert("tab << modify table(column table( 1 ),delete( analysis column(^columns^)))")));
