Aam_jmp
Decimal Format Problem
I have columns where I want to limit the decimal places to 2. Example, 0.335256 should be 0.34. I am using dt:ColumnName << Format( "Fixed Dec", 12, 2 ); and it works perfectly. However, some cells in the columns have values like: <0.00234 for which this Format outputs 0.00, whereas I want <0.00. How can I achieve this? Thank you.
Aam_jmp
Re: Decimal Format Problem
Never mind, I figured I can use PValue to achieve what I wanted. So, the format is : dt:ColumnName << Format( "PValue", 6 ); I still cannot limit it to 2 decimals though!!
Aam_jmp
Jeff_Perkinson
You can use a Custom Format to get what you want.
In the Column Info window choose Format->Custom.
Then click the Set Custom Format format button.
You'll end up in a version of the Formula Editor which will allow you to reformat the value as you wish.
Ultimately it would look something like this.
-Jeff
