ted_ellefson
Date Format help please
Please help me with changing my date time column into a useful JMP column
my formay is yyyymmdd hhmmss
(There is a space in the middle)
example is 20191125 132435 for a Nov 25, 2019 at 1:24 pm 35 secons
I'm not sure how to convert this into a useful JMP format.
I've looked through the multiple date/time related posts, but still don't understand what to do.  Thank you in advance!!!
Re: Date Format help please
Attached is a data table with the conversion formula included.  Here is the formula being used
Date MDY(
	Num( Substr( :my Date, 5, 2 ) ),
	Num( Substr( :my Date, 7, 2 ) ),
	Num( Substr( :my Date, 1, 4 ) )
) + Num( Substr( :my Date, 10, 2 ) ) * 3600
+Num( Substr( :my Date, 12, 2 ) ) * 60
+Num( Substr( :my Date, 14, 2 ) )
ron_horne
Hi @ted_ellefson
please try this:
https://community.jmp.com/t5/Discussions/Customized-Date-Formats/td-p/2974
let us know if it worked,
Ron
Date MDY(
ted_ellefson
THANK-YOU.  The formula works very well.
This Community is awesome
Or you may use the data table tools add-in from brady brady, which allows to convert your date values (as character type in your data table) to a numeric date format while setting the splitpoints, matching the parts to the day/month/year/... and saving this into a new column.
https://community.jmp.com/t5/JMP-Add-Ins/Data-Table-Tools-Add-in/ta-p/28582
There you'll find the instruction document as well, the option you will need is  under:
Data Table Tools -> Special Formula Columns -> Custom Date Formula Writer
The formula you get is the same as @txnelson created.
/****NeverStopLearning****/
