BookmarkSubscribeRSS Feed
statganda
Jun 23, 2011
Customize Quantiles
Hi JMPers,
Is there a way to change the quantiles in the histogram report?
Thanks,
8 REPLIES 8
mpb
Jun 23, 2011
Re: Customize Quantiles
No way built in that I know of. However you can delete the default Quantiles segment and replace it with a custom made one that shows the quantiles you are interested in. The following bare bones example suggests how this might be done.
dt
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: black;">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Open
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"$SAMPLE_DATA/fitness.jmp"
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="font-size: 10pt; font-family: "Courier New"; color: black;">dist
Distribution(
Continuous Distribution(
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Column
style="font-size: 10pt; font-family: "Courier New"; color: navy;">:
style="font-size: 10pt; font-family: "Courier New"; color: black;">Oxy
style="font-size: 10pt; font-family: "Courier New"; color: black;">rdist
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Report
dist )
style="font-size: 10pt; font-family: "Courier New"; color: black;">rdist[
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Quantiles"
style="font-size: 10pt; font-family: "Courier New"; color: black;">]
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><<
delete
style="font-size: 10pt; font-family: "Courier New"; color: black;">maxQ
Quantile
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
style="font-size: 10pt; font-family: "Courier New"; color: teal;">1
style="font-size: 10pt; font-family: "Courier New"; color: black;">medQ
Quantile
style="font-size: 10pt; font-family: "Courier New"; color: teal;">0.5
style="font-size: 10pt; font-family: "Courier New"; color: black;">minQ
Quantile
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Oxy"
style="font-size: 10pt; font-family: "Courier New"; color: black;">])
append(
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Outline
Box
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Table
Box
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">String
Col Box
style="font-size: 10pt; font-family: "Courier New"; color: purple;">""
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"100.0%"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"50%"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"0.0%"
style="font-size: 10pt; font-family: "Courier New"; color: black;">}
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Number
Col Box
{maxQ
medQ
minQ}
style="">
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
statganda
Jun 23, 2011
mpb,
Thanks for the script. It works!!! Thank you very much,
I have another concern.In the histogram, i have frequency data aside from the column,
I tried to add the frequency in the script but it didn't work.
Thanks,
mpb
Jun 23, 2011
There is probably a clever way to do this but here is the outline of a brute force method. The idea is simply to create a matrix version of the table which contains each value as many times as indicated by the frequency column and then to compute the desired quantiles from that matrix. Something like this code would be combined with the previous example in this thread.
style="font-size: 10pt; font-family: "Courier New"; color: green;">/*
Assumes a table with first
column as Y and second column as Freq
style="">
Expands Y column to a single
column matrix with each original Y
style="">
value repeated Freq times */
style="">
style="font-size: 10pt; font-family: "Courier New"; color: black;">dt
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Current
Data Table
style="font-size: 10pt; font-family: "Courier New"; color: black;">()
style="font-size: 10pt; font-family: "Courier New"; color: black;">A
dt
get as matrix
style="font-size: 10pt; font-family: "Courier New"; color: green;">//Show(
A );
style="font-size: 10pt; font-family: "Courier New"; color: black;">expandA
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">For
i
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><=
Rows
dt )
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++,
style="">
yval
A[i
style="">
freqval
A[i
style="font-size: 10pt; font-family: "Courier New"; color: teal;">2
style="">
yval,
freqval );
style="">
expandA
style="font-size: 10pt; font-family: "Courier New"; color: navy;">|/=
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">J
freqval
yval )
expandA );
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Quantile
style="font-size: 10pt; font-family: "Courier New"; color: teal;">0.0
expandA )
expandA )
style="font-size: 10pt; font-family: "Courier New"; color: teal;">1.0
expandA )
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">show
style="font-size: 10pt; font-family: "Courier New"; color: black;">maxQ)
chungwei
Jun 23, 2011
Does Summary not give you what you want ?
mpb
Jun 23, 2011
Summary didn't appear to honor a column with the frequency role for quantiles when I tried it, though it does for means. Perhaps I should say that the results I got using summary on a column where another column with a frequency role existed differed from the results I got using summary on the expanded table. It's possible that the various quantile functions in JMP don't all use the same algorithm to deal with ties. As time permits I'll recheck using summary as that would be preferable.
Ok here's what I tried. I opened the Fitness data and ran Summary for Age which gave me a table of ages and their frequencies (N Rows which I renamed Freq). I gave Freq the frequency role. I ran Summary for Age in the original table and ran it again in the summary table. I chose several quantiles. I found that the 25th and 75th quantiles did not agree though the means did. The quantiles for the summary table were the same as if I had not specified a frequency column.
Message was edited by: mpb
statganda
Jun 23, 2011
Here is the script I have, please check how can I get the P95.
Thanks you very much for the time and effort.
dt = Open ("$SAMPLE_DATA/fitness.jmp");
nw = New window (("Summary"),
Biv = dt << Distribution( Stack(1),
Freq(:Weight),
Column( :Oxy ),
Quantiles (1),
Moments (0),
Outlier Box Plot (0),
Count Axis( 1 ),
Show Percents( 1 ),
Show Counts( 1 ),
), By( :Sex ));
rbiv = Biv << Report();
Summarize( groups = by( :Sex ), reflines = Mean( :Oxy ));
n = N Items( groups );
For( j = 1, j <= n, j++,
rbiv[1][1][1][1][1][1][1][1] <<
add ref line (reflines, solid, "Red" ));
rdist = Report(Biv);
rdist["Quantiles"]<
P95 = Quantile(:Oxy,0.95);
(rdist["Oxy"])< Outline Box ("Quantiles",
Table Box (String Col Box ("",{"95.0%",}),
Number Col Box ("",P95)
mpb
Jun 23, 2011
Not really sure any more what you are trying to do. However the statement "P95 = Quantile(:Oxy,0.95);"
should be
P95 = Col Quantile(:Oxy, 0.95);
to be syntactically correct.
mpb
Jun 23, 2011
Are you trying to do something like this?
style="font-size: 10pt; font-family: "Courier New"; color: black;">nw
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">New
Window
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Summary"
style="">
dist
dt
Distribution(
style="">
Stack(
style="">
Freq(
style="font-size: 10pt; font-family: "Courier New"; color: black;">Weight
style="">
Continuous
Distribution(
style="">
style="">
Quantiles(
style="">
Moments(
style="">
Outlier
Box Plot(
style="">
Count
Axis(
style="">
Show
Percents(
style="">
Show
Counts(
style="">
style="">
style="">
By(
style="font-size: 10pt; font-family: "Courier New"; color: black;">Sex
style="">
style="">
rdist
dist
style="">
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Summarize
groups
by(
reflines
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Mean
P95
style="font-size: 10pt; font-family: "Courier New"; color: teal;">0.95
style="">
style="">
n
Items
groups )
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">j
n
style="">
rdist[
style="font-size: 10pt; font-family: "Courier New"; color: black;">][
delete
style="">
(rdist[
append(
style="">
Box
style="">
Box
Col Box
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"95.0%"
Col Box
{P95[
style="font-size: 10pt; font-family: "Courier New"; color: black;">]}
style="">
style="">
style="">
rdist[
add ref line(
reflines[
solid
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"Red"
style="">
