dspoljaric
Community Trekker
Custom point in DoE
Is ti possible to add custom point (user defined) to already generated design of experiments?
Thanks in advance!
louv
Staff (Retired)
Re: Custom point in DoE
Yes it is. Just manually add a row to your design of experiments table.
louv
Staff (Retired)
dspoljaric
Community Trekker
Ok, thx!
I thought that I need to use some sort of augmented designs.
Since I'm a beginner at this field, I wonder, wouldn't that (possibly?) change the optimality of generated design?
louv
Staff (Retired)
You can certainly use the augment design capability but it would not be "user defined" as you indicated. The optimality would be impacted slightly however all verification runs for that matter would have a minor impact the optimality to a certain degree. If you prefer you could add your "user defined" run manually and then run the augment design to add any additional runs to preserve your optimality but in my opinion and experience I prefer to validate the original design with runs that add value rather than preserve optimality.
dspoljaric
Community Trekker
Thanks for your answers and advice!
