See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Color on indicators
hcarr01
Hello everyone,
I am trying to create a report in JMP to see drifts in certain processes.
For example, I study 6 items in my process and I would like to have an indicator with colors:
- if 5 consecutive points (or more) greater than 3sigma: red color
- if 3 consecutive points (or more) greater than 3sigma: yellow color
- otherwise green color
And then I would like to be able to display in a report something like this per item based on the indicator colors:
undefined
How could I go about having something similar on JMP?
Thank you for your reply.
This post originally written in French and has been translated for your convenience. When you reply, it will also be translated back to French .
Re: Couleur sur des indicateurs
My last script assumed you only wanted the last row in a series to retain the calculated color.  To accomplish what your latest specification, I just commented out the lines that reset the colors if the script determined it wasn't the last row in the series.
names default to here(1);
dt = current data table();
// Créez une nouvelle colonne pour l'indicateur
dt << New Column("Indicateur", Character, Nominal);
one_color = "xyz";
icolor = 0;
For Each Row(
	// If the value of Article has changed set icolor to 0
	If( Lag( :Article ) != :Article,
		icolor = 0
	// If status is red, increment icolor else set it back to zero
	If( :status == "red",
		icolor++,
		icolor = 0
	// Check for the number of icolor
	// Set the value for the cell to the appropriate color
	// When a color is specified remove no longer correct cell colors
	// for previous rows
	If(
		icolor >= 5,
			dt:Indicateur << color cells("red",row());
			//dt:Indicateur << color cells("",row()-1);
			/*If( icolor == 5,
				dt:Indicateur << color cells("",row()-2);
		icolor >= 3,
			dt:Indicateur << color cells("yellow",row());
I'm not sure how this is anymore related to the initial question, but there is a bit different option for creating the indicator column
dt << New Column("Color", Character, Nominal,
	Set Property(
		"Value Colors",
		{"Green" = "Green", "Red" = "Red", "Yellow" = "Yellow"}
	Color Cell By Value,
	Formula(
		is_red = :status == "red";
		If(Row() == 1,
			red_count = is_red;
		If(:Article != Lag(:Article, 1) | is_red == 0,
			red_count = is_red;
			red_count = red_count + is_red;
		If(red_count >= 5,
			"Red";
		, red_count >= 3,
			"Yellow"
			"Green"
12 REPLIES 12
Is each "Item" in a separate column?
Are your data in sequential order"
How many different "Items" are there?
Should the report only have 3 different items in each row of the report?
hcarr01
Is each "Item" in a separate column?  Yes one item by column
Are your data in sequential order"  Yes it can be sort in a sequential order
How many different "Items" are there?  A lot of....
Should the report only have 3 different items in each row of the report?  Yes
One simple option is something like this
dt = New Table("Untitled",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("item",
		Character,
		"Nominal",
		Set Values({"ITEM1", "ITEM2", "ITEM3", "ITEM4", "ITEM5", "ITEM6"})
	New Column("status",
		Character,
		"Nominal",
		Set Values({"Green", "Green", "Red", "Yellow", "Green", "Red"})
lub = Lineup Box(N Col(3));
For Each Row(dt,
	Eval(EvalExpr(
		lub << Append(
			Text Box(:item, << Background Color(Expr(:status)))
nw = New Window("",
	lub
hcarr01
Re: Color on indicators
Thanks for the reply, I'm trying to create a similar table with red, yellow and green indicators.
My goal is to create:
- if 5 consecutive points (or more) are red (above 3 sigma) so the color of the last point is red
- if 3 consecutive points (or more) are red (above 3 sigma) so the color of the last point is yellow
Attached you can find a table that serves as an example, I created the following script but without success:
// Boucle pour calculer l'indicateur ligne par ligne
For(i = 1, i <= N Rows(5), i++,
    // Récupérer les 5 dernières valeurs de l'indicateur
    last_five = dt:status[i,5];  //
    // Comptez le nombre de "rouge"
    count_rouge = N Items( last_five == "rouge");
    // Attribuer une couleur en fonction des règles
    If(count_rouge == 5,
        dt:Indicateur Global[i] = "rouge"; // 5 rouges
        If(count_rouge >= 3,
            dt:Indicateur Global[i] = "jaune"; // 3 ou plus rouges
            dt:Indicateur Global[i] = "vert"; // Sinon vert
I remain confused.  However, given the data table you supplied, which appears to be a table that has the results of what you are attempting to calculate, one can easily color the cells for your Indicateur column
dt=current data table();
:indicateur << color cells("red",dt<<get rows where(:status=="red"));
:indicateur << color cells("yellow",dt<<get rows where(:status=="yellow"));
:indicateur << color cells("green",dt<<get rows where(:status=="green"));
or can create a separate report
nw=new window("colors", lub=lineupbox(ncol(3)));
For Each Row(dt,
	Eval(EvalExpr(
		lub << Append(
			Text Box("Item" || char(:item), << Background Color(Expr(:status)))
If you want to have a table, use data table and color the cells. In graph builder you might be able to use heatmap. If you want to script it, you have many different options where you can set the background color.
pmroz
I think this code does what you want:
dt = New Table( "testcolors", Add Rows( 15 ),
	New Column( "Article", Character, "Nominal",
		Set Values( {"A", "A", "A", "A", "A", "A", "A", "A", "A", "A", "A", "A", "A", "A", "A"}
	New Column( "Item", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15] )
	New Column( "status", Character, "Nominal",
		Set Values(
			{"red", "red", "red", "green", "green", "red", "red", "red", "red",
			"red", "red", "green", "red", "red", "red"}
one_color = "xyz";
icolor = 0;
for (i = 1, i <= nrows(dt), i++,
	one_color = dt:status[i];
	if (one_color == "red",
		icolor++;
	// else
		if (icolor >= 5,
			dt:Indicateur << Color Cells( "Red", i-1 );
			icolor = 0;
		// else
			icolor >= 3,
			dt:Indicateur << Color Cells( "Yellow", i-1 );
			icolor = 0;
// Handle the last row
if (icolor >= 5,
// else
	icolor >= 3,
hcarr01
Hello, thanks for the reply, it works well on this test base!
I'm trying to generalize this script when I have multiple articles. The color indicators are created per article.
I am using the following script but I am not getting the correct end result:
one_color = "xyz";
icolor = 0;
Summarize(dt, unique_objects = by(:Article));
m_obs = dt[0, "Article"];
For each( {unique_objects}, m_obs,
		icolor++;
	// else
		if (icolor >= 5,
			icolor = 0;
		// else
			icolor >= 3,
			icolor = 0;
if (icolor >= 5,
// else
	icolor >= 3,
The result obtained:
undefined
Line 18 should have the yellow color because there are 3 consecutive red points for article B...
Here is my approach
one_color = "xyz";
icolor = 0;
For Each Row(
		icolor = 0
		icolor++,
		icolor = 0
	If(
		icolor >= 5,
			If( icolor == 5,
		icolor >= 3,
