wade-liu
Copy Last Two Column data from Data table A to Data table B
Hi  Everyone
I have a two data table , table A and table B,
I want write a script that copy last two column data from table A then paste to table B,
Could you give me some kindly sugestion ?
Thanks.
Re: Copy Last Two Column data from Data table A to Data table B
Do the tables have exactly same amount of rows and order of data is exactly the same in both of the tables?
wade-liu
Yes, But I don't know how to use script syntax to copy entire column information to another table.
You can use Join/Update or Data table subscripting . Below is one example using update which might work for you
// Setup demo
dt = Open("$SAMPLE_DATA/Trial1.jmp");
dt2 = Open("$SAMPLE_DATA/Little.jmp");
dt << Delete Rows(5 :: N Rows(dt)); // to make tables equal in size
Column(dt2, "batch") << Set Name("B"); // names must be different
Column(dt2, "yield") << Set Name("Y"); // names must be different
Wait(0);
collist = dt2 << Get Column Names("String");
lastcols = Right(collist, 2);
dt << Update(
	With(dt2),
	Add Columns from Update Table(Eval(lastcols)),
	Replace Columns in Main Table(None) // important
