BookmarkSubscribeRSS Feed
mcstagger
Oct 6, 2014
Consumer Research, Categorical: Grouping Variables
Is there a setting that will allow me to set all "0" value labels in a binary variable as missing value codes?
Going through an applying the missing value code to all my grouping variables is a tedious process and one that I know my clients are not going to want to deal with.
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
Re: Consumer Research, Categorical: Grouping Variables
You can use Cols->Standardize Attributes to set the Missing Value Code for lots of columns at once.
Is that what you're looking for?
-Jeff
-Jeff
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
-Jeff
mcstagger
Oct 6, 2014
That is much less tedious. Thank you Jeff!
