キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
Striefster
Changing number of decimals in the tabulate
How can I changed the number decimals in the tabulate function?
As example for the CV (RSD %), I would like to present this table with the values like 38.7, 38.7 and 39.3.
5件の返信5
Striefster
Re: Changing number of decimals in the tabulate
Forgot to add,
and to keep these settings. So when I repeat the tabulate function the decimals stay the same.
And can I copy this table into Excel, to change the fonts and styles.
Which JMP version are you using? In JMP18 you have these
Striefster
Thanks Jarno!
Yes that's true but with JMP17 isn't saved. So when you redo a tabulate you have to change the format again.
The only option is to work via a script, I think. I hoped it would be easier via a simple checkbox.
Where do you find "Change Format" option?
WineAroma
In the Tabulate window, scroll down to the bottom. You’ll find it in the lower-left corner right below “Default Statistics.”
おすすめの記事
