user2
Item Wrap and Max Items - Default Legend Settings
Is there anywhere in settings to set the Item Wrap and Max Items fields of Graph Builder to a different number? I often run data with a lot of categories where the Max items is way too short. Not to mention that on a regular screen the Item Wrap almost always ends up wasting a lot of space, instead of doing one long column and allowing the graph to expand.
I tried looking it up, but the search engine is off to some unrelated results.
Running JMP 18.0.1
Re: Item Wrap and Max Items - Default Legend Settings
I don't think there are preferences for those but you might be able to create a preset for that: Create empty graph builder, go to legend settings from red triangle menu, modify them as you would like them to be and then save your preset. And when you wish to use this, you can quite easily load it from the preset menu.
Also if you wish to be able to modify those from preferences, you can make a wish list item to JMP Wish List
user2
Thanks, for the pointers. I've been using JMP for a few years and was unaware that one could have presets!
I do feel like this should be available as a setting, so I've submitted the request to JMP Wish List also.
Wish can be found from hereItem Wrap and Max Items - Default Legend Settings
