restonian
Can you remove all menu items from New Window() ?
I'd like to remove all the default menu items from the Window I create when using the New Window() function.
I didn't find any documentation on this in the "JMP 10  Scripting Guide" that I'm using to learn JSL.
The default menu items have no meaning within my application, and I like to be able to present the users with an uncluttered dialog box.
Thanks for your help.
Robert
ms
Super User (Alumni) ms
Re: Can you remove all menu items from New Window() ?
New Window has many options (hold mouse pointer over the command in jsl editor to see all options).
Maybe this does what you want:
nw=new window("uncluttered", show menu(0), show toolbars(0));
ms
restonian
Thanks MS, thoes arguments did the trick along with the hover suggestion!  I went back to  Scripting Guide and did find the New Window ()  function documented in Appendix A.
