paulp
select text between delimiters
Hello,  I'm trying to write a formula to select text that lies between the delimiters [ ].
All text in my column appears as below:
RinseAid[Apex.Rinse]*(Temp-130)
RinseAid[AutoDri]*(Temp-130)
RinseAid[Bright&Dry]*(Temp-130)
RinseAid[Clarity]*(Temp-130)
I want to keep only the text between the [ ] symbols:
Apex.Rinse
AutoDri
Bright&Dry
Clarity
But using a formula such as below, Iget a mesage that the formula requires a character
Starts With( :Term, "[" ),
Any ideas?  thanks, Paul
ms
Super User (Alumni) ms
Re: select text between delimiters
Starts with() returns 0 or 1.  If that is part of a formula that require character argument, that could explain the error message. However, Starts with() alone would not give that error if :Term is a character column.
In this case,  the Word() function should work.
Paste this into a column formula
Word( 2, :Term, "[]" )
Or if you want to replace the values in the :Term column, try running this script (assumes there is always some text before "[")
For Each Row( :Term = Word( 2, :Term, "[]" ) );
Regex() can also be used and allows a more fool-proof search. However, here it requires some extra effort since \[ and \] have special but different meaning in jsl and grep.
But this should work:
regex(:Term,"\[\[(.+?)\]\]","\1");
Message was edited by: Marcus Sundbom
Added Regex()
