I'm trying to figure out how I can use JMP to solve the following problem. I have a data set with a bunch of values in each row. What theoretical technique/how do I use JMP to determine if there are any relationships between 1 or more values. (for example, if I have A in the record, you will most likely have B, C, and D as well.
The rows would be encoded like this:
A B C D E
A B
C Q
R S T
A D
D A
E M
R Z
R S T L N E
A B
A D E
A B D E
