BookmarkSubscribeRSS Feed
Auto Centering in Scroll Boxes
msharp
Jul 28, 2015
I got another toughy.  I can't get the auto centering to work inside a scroll box.  Not sure if this is intended behavior or just a bug.  Here's the "Set Auto Centering" Scripting Index example modified to include a Scroll Box.  You can see that the auto centering/streching no longer works for objects inside the Scroll Box.  If anyone has a suggestion or work around I'd appreciate it.
//This message applies to all display box objects
New Window( "Example",
	H List Box(
		tv = Text Box( "V+V", <<rotate text( left ) ),
		Scroll Box(V List Box(
			Text Box( "resize the containing window" ),
			th = Text Box( "H+H" ),
			ts = Spacer Box(
				<<Size( 10, 30 ),
				<<Color( "blue" )
tv << set auto centering( 0, 1 );
th << set auto centering( 1, 0 );
th << set auto stretching( 1, 0 );
ts << set min size( 5, 20 );
ts << set max size( 100000, 100 );
ts << set auto stretching( 1, 1 );
Show( th << get auto centering() );
Show( ts << get auto stretching() );
Show( ts << get min size() );
Show( ts << get max size() );
