Jackie_
Adding numbers to columns
@txnelson,
I am new to JSL Scripting.
Is there a way I could number all the columns using a jsl script? There are 100 columns in the data table and I want to concatenate number in the column names
 On example, there are multiples columns that follow this type:-
Looking for some feedback
Thanks,
Jay
ih
Super User (Alumni) ih
Re: Adding numbers to columns
Hi @Jackie_ ,
You could use a short script to do this:
Names default to here(1);
dt = Open("$Sample_data/iris.jmp");
cols = dt << Get column names;
for(c = 1, c<= n items(cols), c++,
	Column(dt, c) << Set Name( char(c) || ". " || ( Column(dt, c) << Get Name ) )
ih
Hi @Jackie_ ,
Jackie_
Thanks, @ih
I want to assign numbers only to a particular group of columns.
For eg: In this case, I want to serialize the column group "Tests". There are more than 100 columns in the tests groups. Please can you help me with the jsl?
Many thanks,
Jack
ih
If you are working interactively then the function get selected columns might help:
dt:Sepal length << Set Selected(1);
dt:Sepal width << Set Selected(1);
cols = dt << Get selected columns;
Otherwise you could include an if statement in the for loop to ensure the name matches whatever criteria you have.
If you are using JMP16 you could also try  with Transform Each (or For Each):
Transform Each({value, idx}, dt << Get Column Names("String"),
	Column(dt, value) << Set Name(Char(idx) ||". " || value);
  1. Please take the time to read the Scripting Guide in the JMP Documentation Library available under the Help pull down menu.
  2. All you need to do, is to loop across the columns and change the column name
    For( i = 1, i <= N Cols( dt ), i++,
    	Column( dt, i ) << set name( Char( i ) || ". " || Char( Column( dt, i ) << get name ) )
