There really haven't been any JSL upgrades to the 3D Scatterplot Platform, however, I believe the following technique will work, and I believe that it actually was available in 2014. What I do to create the following display
![jennifer_n_blak.PNG jennifer_n_blak.PNG](https://community.jmp.com/t5/image/serverpage/image-id/8297i3D2F393D90EFFBFD/image-size/large?v=v2&px=999)
is to create a new column that only has a value for the 2 rows that I want to draw a line between, and then I use
![jennifer_n_blakb.PNG jennifer_n_blakb.PNG](https://community.jmp.com/t5/image/serverpage/image-id/8298i2F2B8C54D108D6F7/image-size/large?v=v2&px=999)
the Connect Points, grouped by the new column, and it draws a line just between those 2 points. Below is a sample script
dt = New Table( "The Line",
Add Rows( 40 ),
New Column( "age",
Numeric,
"Ordinal",
Format( "Fixed Dec", 5, 0 ),
Set Values(
[12, 12, 12, 13, 13, 13, 12, 12, 13, 16, 14, 13, 12, 12, 14, 14, 15, 15, 17, 14, 14,
13, 14, 14, 14, 15, 13, 15, 16, 14, 14, 15, 15, 12, 15, 14, 16, 17, 14, 17]
New Column( "height",
Numeric,
"Continuous",
Set Values(
[51, 52, 55, 56, 58, 59, 59, 60, 60, 60, 61, 61, 61, 61, 62, 62, 62, 62, 62, 63, 63,
63, 64, 64, 64, 64, 65, 65, 65, 65, 65, 66, 66, 66, 67, 68, 68, 68, 69, 70]
New Column( "weight",
Numeric,
"Continuous",
Set Values(
[79, 64, 74, 67, 95, 79, 95, 84, 112, 115, 81, 107, 123, 128, 85, 91, 92, 104, 116,
84, 93, 105, 92, 99, 99, 112, 98, 111, 112, 119, 142, 105, 106, 145, 128, 112, 128,
134, 113, 172]
New Column( "Grouping",
Character,
"Nominal",
Set Values(
{"", "Line", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "",
"", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "Line"}
dt << Scatterplot 3D(
Y( :age, :height, :weight ),
Connect Points( 1, :Grouping ),
Frame3D(
Set Grab Handles( 0 ),
Set Rotation( -22.7391193234154, 33.6106458355737, 86.1083668103014 ),
Set Marker Quality( 0.3875 ),
Set Marker Scale( 1.21375 )
