BookmarkSubscribeRSS Feed
Accumulate column data
terapin
Jun 23, 2011
How do I use the lag operator to add up data on a row wise basis? That is, I want to accumulate data from column tair in a new column called chilling degree if the tair value is > 5.
tair chilling degree
5 5
7 5
5 10
afterword
Jun 23, 2011
I don't know the answer to this question, but it sounds like you're working with building energy data. Am I right? That's my field as well so I'd be happy to trade scripts and files with you.
If you want to simply accumulate values in a column, you don't necessarily need the lag operator. If you want to accumulate data (get a cumulative sum) for a column called "tair", do the following:
1. Create a new column. In this example, I call it "total".
2. Put the following formula in the new column:
(ignore this line)
The formula takes the value of tair in the current row, and adds it to the previous value of total, thus creating a cumulative sum.
If you only want to accumulate the values if they are greater than or equal to 5, then use the formula:
(ignore this line)
The formula looks at the current value of tair, and if it is less than 5, instead of adding tair, it adds 0.
