BookmarkSubscribeRSS Feed
sasrookie
Jul 25, 2012
Accessing unique values of a column in control chart code
Started to work on JMP for the last couple of weeks and have a question on how to get unique values from a column and use those values as inputs in designing a control chart.
  1. Step 1: Importing an excel sheet; this step works fine.
  2. Step 2: Trying to create a control chart from the excel sheet data. However I need help in the Track Names part where Track Names is a column in the excel sheet which has duplicate values. What I want to do is first create a unique set of values from that column and then use those unique set of values in the for loop. I have highlighted the part in yellow where I am stuck..
  3. My thoughts: Initially what I did is load the unique track names ( done manually in excel) as a list and then tried to access the contents of the list in the for loop by using the show command. However that doesn't work. Not sure the exact reason but I think its mainly because I'm accessing the week and calculation column from the excel sheet but the Track name from the list so I guess JMP doesn't like that.
Please let me know how to go forward with this. Thank you for your help in advance.
//Selecting the JMP Table sheet from the Consolidation Macro excel file.
Open Database("DSN=Excel Files;DBQ=C:\Users\XXX.xlsm;DriverId=1046;MaxBufferSize=2048;PageTimeout=5;",
"SELECT * FROM `abc$`","abc Data table$");
A = {"John","Pace","Rodriguez"};     // Created a unique list from the Track Names column manually.
New Window( "Control Charts for NA & LA Client",
V List Box(
for(i=1,i<=NItems(A),i++,
Control Chart(
Sample Label( :WEEK ),
//Alarm Script( Write( "i,", qc_test, ",", qc_col, qc_sample, "\!N" ) ),
Group Size( 1 ),
Ksigma( 3 ),
Chart Col( :Calculation, Individual Measurement( Show Zones( 2 ), Shade Zones( 2 ), Test 6( 1 ) ) ),
Where( :Track Names == show(A) ),
pmroz
Jun 23, 2011
Re: Accessing unique values of a column in control chart code
This function will give you the unique values in a column:
/* Function Name    Get Unique Values
Description:    Get the unique values for a column.  For example:
    Indications
    AAAAA
    BBBBB
    AAAAA
    CCCCC
    CCCCC
unique_list = get unique values (:Indications)
will return {"AAAAA", "BBBBB", "CCCCC"}
Arguments:
dtcol        column descriptor to calculate unique values for
Get Unique Values = Function( {dtcol},{default local},
// Eval/expr trickery to get this to work.
    eval(eval expr(
        Summarize(unique_list = By(expr(dtcol)))));
    unique_list;
);    // end get unique values
sasrookie
Jul 25, 2012
Thanks for your prompt reply...Not sure I understood your answer...I'm trying to use this but not getting it..
    eval(eval expr(
        Summarize(unique_list = By(expr(: Track Names)))));
    unique_list;
pmroz
Jun 23, 2011
That's a function that will allow you to dynamically get the unique values in a column.  Put the function in as the first part of your code, and then call it like this:
alist = get unique values(:Track Names);
I'm not sure how you would use it for the control chart section of your code though.
