  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
"Color Code()" JSL Function
It will be convenient if there is a function that accepts a value and a name of a color gradient and returns a color code.
4 Comments
Craige_Hales
Check out the HeatColor( value, <<theme ) function. It was originally named for a single theme that returned blue-to-gray-to-red representing cold to hot.
Also see GetColorThemeNames(). Both are in the scripting index for JMP 14, maybe earlier.
drawing rectangles from the color themedrawing rectangles from the color theme
also https://community.jmp.com/t5/Uncharted/Can-JSL-use-custom-Heat-Colors/ba-p/34010
nao
Level IV
Thanks! That's exactly what I wanted. Accept my apologies for bothering. I hope this page will also help someone else.
Jeff_Perkinson
Community Manager
Status changed to: Already Offered
Ryan_Gilmore
Community Manager
Status changed to: Delivered
