  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Add a ruler to Graph Builder
Often I want to know the distance in x, y, and absolute distance between points.  I can't find any way to do this currently in JMP.
Gnuplot has a mode where you press a key and it anchors a start point, then you can move the mouse around in the window and it shows the delta-x, delta-y, and distances of the mouse from the start point.
Something like this in JMP would be very handy!
7 Comments
Jeff_Perkinson
Community Manager
We're working on this for JMP 16.
BHarris
Level VII
Awesome, can't wait.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
JMP 16 now has a ruler tool that works in (most) every graph, not just Graph Builder.
BHarris
Level VII
Awesome, it's very smooth.  Nicely done!
I showed it to my lead, and he said -- "Looks great... but no angle?"  Hm.
I was also thinking it might be nice to get a cross-hairs view for selecting the points.
Vball247
Level V
This works great. Follow-up question. Does anyone know how to have it freeze in the graph? Would be nice to have it stay. In windows able to make it stay if you take a screen shot, does not disappear until you click back on the graph. But would be nice not to have to stretch fingers of one hand for screen shot while holding down the mouse.
BHarris
Level VII
I think @hogi  figured out that if you drag the ruler, then mid-drag you do a right-click, that opens the context menu leaving the ruler up.  Then you can click somewhere else to dismiss the context menu and the ruler stays put.
hogi
Level XIII
https://community.jmp.com/t5/JMP-Wish-List/Keep-Ruler-permanent-on-graph/idc-p/779014/highlight/true...
could be that I found the trick somewhere else in the community ...
