Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Check out the HeatColor( value, <<theme ) function. It was originally named for a single theme that returned blue-to-gray-to-red representing cold to hot.
Also see GetColorThemeNames(). Both are in the scripting index for JMP 14, maybe earlier.
