%3CLINGO-SUB%20id%3D%22lingo-sub-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3Eaggiungere%20limiti%20di%20tolleranza%20del%20controllo%20della%20coda%20a%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EPer%20i%20limiti%20di%20tolleranza%20della%20teoria%20normale%20bilaterale%20ci%20sono%20due%20approcci%20basati%20sul%20contenuto%3A%3C%2FP%3E%3COL%3E%3CLI%3Eassicurare%20che%20l'intervallo%20copra%20almeno%20p%20proporzione%20della%20popolazione%20con%20la%20confidenza%20specificata%3C%2FLI%3E%3CLI%3Eassicurarsi%20che%20l'intervallo%20non%20copra%20pi%C3%B9%20di%20(1-p)%2F2%20da%20ciascuna%20coda%20della%20popolazione%3C%2FLI%3E%3C%2FOL%3E%3CP%3E(cfr.%20Hahn%20e%20Meeker%20%5B1991%2C%202017%5D%20o%20Krishnamoorthy%20e%20Mathew%20%5B2009%5D).%20Il%20secondo%20approccio%20(introdotto%20da%20Owen%2C%201964)%20%C3%A8%20pi%C3%B9%20rigoroso%2C%20producendo%20intervalli%20pi%C3%B9%20ampi%2C%20ma%20direttamente%20correlato%20a%20un%20limite%20di%20confidenza%20inferiore%20esatto%20per%20l'indice%20di%20capacit%C3%A0%20del%20processo%20Cpk%20(cfr.%20Chou%2C%20Owen%20e%20Borrego%2C%201990).%20Attualmente%2C%20JMP%20offre%20solo%20il%201%C2%B0%20tipo.%20Aggiungere%20il%202%C2%B0%20tipo%20come%20opzione.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EOrganizzazione%20dei%20contenuti%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EIngegneria%20della%20qualit%C3%A0%20e%20dei%20processi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-841360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20aggiungi%20limiti%20di%20tolleranza%20del%20controllo%20della%20coda%20a%20JMP%20-%20Stato%20modificato%20in%3A%20Riconosciuto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-841360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E
add tail control tolerance limits to JMP
For 2-sided normal theory tolerance limits there are two approaches based on content:
  1. assure that the interval covers at least p proportion of the population with specified confidence
  2. assure that the interval covers no more than (1-p)/2 from each tail of the population
(cf. Hahn and Meeker [1991, 2017] or Krishnamoorthy and Mathew [2009]). The second approach (introduced by Owen, 1964) is more stringent, producing wider intervals, but directly related to an exact lower confidence bound for process capability index Cpk (cf. Chou, Owen, & Borrego, 1990). Currently, JMP only offers the 1st type. Please add the 2nd type as an option.
1 Comment
