%3CLINGO-SUB%20id%3D%22lingo-sub-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EF%C3%BCgen%20Sie%20JMP%20Toleranzgrenzen%20f%C3%BCr%20die%20Hecksteuerung%20hinzu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EF%C3%BCr%20die%202-seitigen%20Toleranzgrenzen%20der%20Normaltheorie%20gibt%20es%20zwei%20inhaltlich%20orientierte%20Ans%C3%A4tze%3A%3C%2FP%3E%3COL%3E%3CLI%3EStellen%20Sie%20sicher%2C%20dass%20das%20Intervall%20mindestens%20p%20Anteile%20der%20Grundgesamtheit%20mit%20der%20angegebenen%20Konfidenz%20abdeckt.%3C%2FLI%3E%3CLI%3EStellen%20Sie%20sicher%2C%20dass%20das%20Intervall%20nicht%20mehr%20als%20(1-p)%2F2%20von%20jedem%20Ende%20der%20Population%20abdeckt%3C%2FLI%3E%3C%2FOL%3E%3CP%3E(vgl.%20Hahn%20und%20Meeker%20%5B1991%2C%202017%5D%20oder%20Krishnamoorthy%20und%20Mathew%20%5B2009%5D).%20Der%20zweite%20Ansatz%20(eingef%C3%BChrt%20von%20Owen%2C%201964)%20ist%20strenger%20und%20f%C3%BChrt%20zu%20breiteren%20Intervallen%2C%20steht%20aber%20in%20direktem%20Zusammenhang%20mit%20einer%20exakten%20unteren%20Konfidenzgrenze%20f%C3%BCr%20den%20Prozessf%C3%A4higkeitsindex%20Cpk%20(vgl.%20Chou%2C%20Owen%20%26amp%3B%20Borrego%2C%201990).%20Derzeit%20bietet%20JMP%20nur%20den%201.%20Typ%20an.%20Bitte%20f%C3%BCgen%20Sie%20den%202.%20Typ%20als%20Option%20hinzu.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-469530%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EInhaltsorganisation%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EQualit%C3%A4ts-%20und%20Prozesstechnik%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-841360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBetreff%3A%20Hinzuf%C3%BCgen%20von%20Toleranzgrenzen%20f%C3%BCr%20die%20Endsteuerung%20zu%20JMP%20-%20Status%20ge%C3%A4ndert%20in%3A%20Best%C3%A4tigt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-841360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3C%2FLINGO-BODY%3E
add tail control tolerance limits to JMP
For 2-sided normal theory tolerance limits there are two approaches based on content:
  1. assure that the interval covers at least p proportion of the population with specified confidence
  2. assure that the interval covers no more than (1-p)/2 from each tail of the population
(cf. Hahn and Meeker [1991, 2017] or Krishnamoorthy and Mathew [2009]). The second approach (introduced by Owen, 1964) is more stringent, producing wider intervals, but directly related to an exact lower confidence bound for process capability index Cpk (cf. Chou, Owen, & Borrego, 1990). Currently, JMP only offers the 1st type. Please add the 2nd type as an option.
1 Comment
