  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
add rows - add full documentation to Scripting Index
There is lacking documentation on how to use this feature.
I would like the full documentation of "add rows" to be added to Scripting Index.
This is the "add rows" function that is used in JMP JSL like: dt << add rows(1);
I would like to know how to add rows to the end of the data table.
Why is this idea important?
All users need to have documentation of features to use JMP effectively.
2 Comments
bswedlove
Level IV
I see now that there is documentation for Add Rows, but no example of each different way that Add Rows can be used.
Could you please add an example for add rows at start and at end?
jthi
I'm not sure if this is issue with lack of examples or with the sometimes confusing syntax used in different places of JMP documentation. The syntax
obj << Add Rows( <n>, <At Start|At End|After(m)> | {list of (column name = value) pairs})
means that you have optional n (count), and you have optional list of position options OR key value pairs in a list (you cannot have both). I'm not sure if there is single document which explains this syntax (and if I remember correctly, it isn't consistent). Very small amount of explaining can be found from Scripting Guide Conventions (jmp.com) (there might have been also better help page, but I cannot find it). So to answer how to add rows to end of data table -> take example using After and replace the After(5) with At End.
Also using Help button from scripting index does help sometimes: Data Table Messages (jmp.com) -> Add Rows (jmp.com).
Comprehensive scripting index for wish list item, JMP Scripting Index feedback and discussion for older community post.
