add modulo to the NewFormulaColumn menu
☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
In the NewFormulaColumn/Transform menu there are many useful functions, but "modulo" is missing:
19 Comments
hogi
Level XI
mia_stephens
Status changed to: New
Hi @hogi , we see you : )
You have many very good suggestions, and in all honesty, it's a bit hard to keep. We do evaluate each request to determine how to best proceed based on current development priorities and backlogs, and it's not feasible or even desirable to address every request.
The intent with New Formula Column is to provide easy access to the most commonly used functions. As you can imagine, the list can quickly grow, making it harder to use this feature as intended. While we've marked this as Not Planned for Now, it is still on our list and we will revisit if there are other requests.
Thank you for your contributions to helping make JMP better,
Mia
mia_stephens
Thanks for the suggestion @ih ! Adding a custom function makes a lot of sense here.
hogi
Level XI
@mia_stephens , @ih , yes I agree.
Here is the respective wish:
New Formula Column menu: user-Defined mini GUIs
If  such miniGUIs can be added to the new-formula right click menu, wishes like this one here are no longer necessary
mia_stephens
@hogi , alas, we've got a lot in the pipeline already and unfortunately we can't act on every request. There are just so many good ideas!
We'll evaluate the mini-GUIs request separately and will add comments on that post. Thanks!
hogi
Level XI
ok, just ping me when you need further info
hogi
Level XI
@Sarah-Sylvestre , this wish can be closed.
the New Formula column - new entry: draft function in JMP18 is wonderful.
With 2 additional clicks a user can create whatever function is needed.
Thanks a lot for providing the new functionality.
Status changed to: Archived
