Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Thank you for this additional information @hogi. We have not received other requests for modulo to be added to New Formula Column, and I'm sure you appreciate that the menus of functions can get quite long so additions are carefully evaluated.
If this is something you do regularly, have you considered a scripted solution?
And the more generic issues with scripting everything where you have to keep them updated over different JMP versions which quite commonly break things and validating them (instead of trusting that JMP has done the validation).
Let's hope that the wish gets into a future release - even without Kudos ...
Nevertheless, every basic arithmetic operator should already be in the list by default - if necessary: in a submenu. The majority is there **). Division is not directly available - but indirectly via Scale Offset/Multiplier. So, no issue. But modulo is completely missing. Concerning importance:
For C++ the modulo operator was important enough to reserve a character for it. ***) So, it's definitely not one of those strange functions which you hear and forget - and never use.
*) Could be that the current approach to hide new wishes in the wish list menu is not a good idea.
**) Some while ago I feared that Jmp also kept the multiplication from the right click new formula column menu - but in this case it was just difficult to find it ;)
No I do not know of a way to add a dialog box to the custom transformation formula interface. It might be possible though, that might be a good discussion post.
Note the Transform Category message which make the custom function available in the right-click menu.
Hi @mia_stephens : Following @ih 's solution, I asked the community for a way how to add the desired Modulo miniGui to the New Fomula Column right click menu.
