add "rescale" to new formula column right click menu
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
In the NewFormulaColumn/Transform menu there are many useful functions, but a simple rescale function is missing.
The idea:
a window opens and the user can enter a scaling factor.
then a new column is created with the rescaled vales.
If more than one column is selected, let's say N,  the window contains a list of N number edit boxes.
There should also be a checkbox to tell the function to use the first rescaling factor for all new columns.
3 Comments
hogi
Level XIII
Ah, it's already there:
-> "scale offset" :)
the suggested "multi-column" features are not worth to add.
Sarah-Sylvestre
Level V
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
Status changed to: Delivered
@hogi, disregard the last comment - I meant to mark this as delivered. Thanks!
