  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
personal presets for "new formula column" right click menu
I often have to apply the same formula to correct input data.
Is there a way to define a list of personal formula presets that can be quickly used via the "new formula column" right click menu?
e.g.
Num(Substitute( ..., ",","."))
to convert columns with comma decimal separator to numbers - just with a single click.
(Very convernient till there will be some settings to choose in the separator in the csv input dialog :)
5 Comments
Sarah-Sylvestre
Level V
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
Sarah-Sylvestre
Level V
Sarah-Sylvestre
Level V
Hi @hogi! I wanted to make sure you are aware that you can define a custom function and this allows you to add it to the new formula menu. You have to define the custom function in your startup.jsl or an addin (because the definition doesn’t persist). Would this fulfill your request?
hogi
Level XIII
Hi Sarah,
custom functions are fine.
I fond them after filing the request.
The request can be closed.
Sarah-Sylvestre
Level V
Status changed to: Not Planned For Now
