DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
Basically, several platforms (such as Distribution, Fit Y by X) have a command to arrange the plots in rows to allow a user-defined layout grid. Variability Gauge doesn't seem to have it, which is what I'm requesting here.
On a somewhat related note, it would also be useful to provide a similar option for Contour Plots.
Hi @MShroff , I've discussed with the developer and we're not certain what this change would look like in the Variability Gauge platform, as the charts are currently in rows. Are you talking about when there are multiple Y's? Do you have a sketch or mock up you can provide for an example?
Shown below is a screenshot of the relevant command from Fit Y by X (as an example). This is what I'm requesting be added in Variability Gauge, which isn't currently avaiable. This would allow customizing the placement of multiple plots.
Thanks
Mehul Shroff
