Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Basically, several platforms (such as Distribution, Fit Y by X) have a command to arrange the plots in rows to allow a user-defined layout grid. Variability Gauge doesn't seem to have it, which is what I'm requesting here.
On a somewhat related note, it would also be useful to provide a similar option for Contour Plots.
Hi @MShroff , I've discussed with the developer and we're not certain what this change would look like in the Variability Gauge platform, as the charts are currently in rows. Are you talking about when there are multiple Y's? Do you have a sketch or mock up you can provide for an example?
Shown below is a screenshot of the relevant command from Fit Y by X (as an example). This is what I'm requesting be added in Variability Gauge, which isn't currently avaiable. This would allow customizing the placement of multiple plots.
Thanks
Mehul Shroff
