Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Basically, several platforms (such as Distribution, Fit Y by X) have a command to arrange the plots in rows to allow a user-defined layout grid. Variability Gauge doesn't seem to have it, which is what I'm requesting here.
On a somewhat related note, it would also be useful to provide a similar option for Contour Plots.
Hi @MShroff , I've discussed with the developer and we're not certain what this change would look like in the Variability Gauge platform, as the charts are currently in rows. Are you talking about when there are multiple Y's? Do you have a sketch or mock up you can provide for an example?
Shown below is a screenshot of the relevant command from Fit Y by X (as an example). This is what I'm requesting be added in Variability Gauge, which isn't currently avaiable. This would allow customizing the placement of multiple plots.
Thanks
Mehul Shroff
