Update & Concatenate: source script collision
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2023
we have a workaround -> don't need it anymore.
Short:
Tables/Update and Tables/Concatenate destroys my source scripts.
STOP THEM !!!
Long:
Many of the Platforms in the Tables menu provide the option Save Script to Source Table.
Is is an elegant way to save the command with all the settings as a Table Script Platform_Name Script.
There is even an auto-increment function which prevents Jmp from overwriting previous Table Script with the same name.
But there are two exceptions: Update and Concatenate.
As all the other functions, Concatenate saves the command script as a Table Script (name: source) to the output table.
Exception: If the option Append to first table is enabled, the main table is the output table - and NO script is saved (perhaps to prevent Jmp from over-writing an existing source Table script?)
For Update the main table is always used as output table. This function saves a table script with the current settings (name: source) to the main table and thereby: overwrites any existing source table script (!).
Table / Update - source script collision
Concatenate and Update should follow the naming scheme of the other Table platforms.
i.e. save a script with the current settings to a Table Script with name Concatenate Script or Update Script.
An auto-increment feature should be used to prevent Jmp from overwriting existing scripts.
Why is this idea important?
The auto-generation of JSL source code is a great feature.
But over-writing an existing source code is more ham than good .
Fixing the issue will save users from losing their table source script.
The naming convention separates source scripts (name: source;  was used to generate the data table) from Platform Scripts (name: Script; can be used to act on the current data table)
8 Comments
Sarah-Sylvestre
Level V
Hi @hogi, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
hogi
Level XIII
I asked Jmp Support if the current behavior *) can be treated as a bug: 00035426
*) Tables/Update and Tables/Concatenate overwrite source Scripts. No undo available.
the answer is: No
"For almost all data table manipulations, a Source script is written to the table.  If one is already there, it is overwritten.  This is how it has worked for many years.  It is not a bug, it is intentional behavior.  ..."
Am I the only Jmp user who uses Source Scripts? - the only one who lost a source script by a Tables/Update of the data table?
hogi
Level XIII
but even if it is not interpreted as a bug ...
and if I am the ONLY Jmp user who enjoys the automatically generated source script ...
(alternative: I I am the only jmp user who uses Tables/Update AND Source scripts)
pleaaaase: fix it :)
With every destroyed source script: it hurts so much!
hogi
Level XIII
hogi
Level XIII
  • If a new table is generated and a table with the same name exists, a “ 2” is added – or the counter is increased by one.
  • If a new column is generated and a column with the same name exists, a “ 2” is added – or the counter is increased by one.
  • In JMP18 - if a new Update Script *) is generated and a script with the same name exists, a “ 2” is added – or the counter is increased by one.
  • If a table is updated via concatenate or update, the existing Source script is overwritten with the auto-generated one.
*) Update Script after Excel import:
thanks for implementing this feature in Jmp18.
hogi
Level XIII
Ah, this is a very interesting plot!  - let's use the Source script of the data set to find out where the data comes from ....
hm ...
hogi
Level XIII
@Sarah-Sylvestre
For our company we fixed the behavior of Tables/Update and Tables/Concatenate.
-> wish can be closed.
if somebody needs the bugfix, please send me a PN.
hogi
Level XIII
