  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Update & Concatenate: source script collision
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2023
we have a workaround -> don't need it anymore.
Short:
Tables/Update and Tables/Concatenate destroys my source scripts.
STOP THEM !!!
Long:
Many of the Platforms in the Tables menu provide the option Save Script to Source Table.
Is is an elegant way to save the command with all the settings as a Table Script Platform_Name Script.
There is even an auto-increment function which prevents Jmp from overwriting previous Table Script with the same name.
But there are two exceptions: Update and Concatenate.
As all the other functions, Concatenate saves the command script as a Table Script (name: source) to the output table.
Exception: If the option Append to first table is enabled, the main table is the output table - and NO script is saved (perhaps to prevent Jmp from over-writing an existing source Table script?)
For Update the main table is always used as output table. This function saves a table script with the current settings (name: source) to the main table and thereby: overwrites any existing source table script (!).
Table / Update - source script collision
Concatenate and Update should follow the naming scheme of the other Table platforms.
i.e. save a script with the current settings to a Table Script with name Concatenate Script or Update Script.
An auto-increment feature should be used to prevent Jmp from overwriting existing scripts.
Why is this idea important?
The auto-generation of JSL source code is a great feature.
But over-writing an existing source code is more ham than good .
Fixing the issue will save users from losing their table source script.
The naming convention separates source scripts (name: source;  was used to generate the data table) from Platform Scripts (name: Script; can be used to act on the current data table)
8 Comments
Sarah-Sylvestre
Level V
Hi @hogi, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
hogi
Level XIII
I asked Jmp Support if the current behavior *) can be treated as a bug: 00035426
*) Tables/Update and Tables/Concatenate overwrite source Scripts. No undo available.
the answer is: No
"For almost all data table manipulations, a Source script is written to the table.  If one is already there, it is overwritten.  This is how it has worked for many years.  It is not a bug, it is intentional behavior.  ..."
Am I the only Jmp user who uses Source Scripts? - the only one who lost a source script by a Tables/Update of the data table?
hogi
Level XIII
but even if it is not interpreted as a bug ...
and if I am the ONLY Jmp user who enjoys the automatically generated source script ...
(alternative: I I am the only jmp user who uses Tables/Update AND Source scripts)
pleaaaase: fix it :)
With every destroyed source script: it hurts so much!
hogi
Level XIII
hogi
Level XIII
  • If a new table is generated and a table with the same name exists, a “ 2” is added – or the counter is increased by one.
  • If a new column is generated and a column with the same name exists, a “ 2” is added – or the counter is increased by one.
  • In JMP18 - if a new Update Script *) is generated and a script with the same name exists, a “ 2” is added – or the counter is increased by one.
  • If a table is updated via concatenate or update, the existing Source script is overwritten with the auto-generated one.
*) Update Script after Excel import:
thanks for implementing this feature in Jmp18.
hogi
Level XIII
Ah, this is a very interesting plot!  - let's use the Source script of the data set to find out where the data comes from ....
hm ...
hogi
Level XIII
@Sarah-Sylvestre
For our company we fixed the behavior of Tables/Update and Tables/Concatenate.
-> wish can be closed.
if somebody needs the bugfix, please send me a PN.
hogi
Level XIII
