  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Set (next) focus on TextEditBox
Hello
I want to automate entring numbers in a window manually or by a barcode scanner and create a certain flow for inputs.
The idea would be to enter the next object as a parameter like:
teb = text edit box("example",set width(160),set nlines(1),<<setscript(my_expr),<<nextObj(XYZ))
or by the command <<setfocus() for MouseBox
This would make it possible to design a flow through the boxes and re-focus on the box itself when a series of inputs are needed (like the << restore focus after click(1) for ButtonBox).
5 Comments
Ryan_Gilmore
Community Manager
Status changed to: Archived
jthi
I think this request is still relevant if JMP17 doesn't offer this functionality. I have also made wish list item with wider scope Allow SetFocus to be used with interactive display elements (TextEditBox, Button...)
Mauro_Gerber
Level IV
Thank you @jthi , I still hope this get's implemented in  JMP18.
hogi
Level XIII
Thank you for the feedback. I am reopening this request.
