  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Non-linear models in Fit Curve with fixed or constrained parameters and add more non-linear models to Fit Curve
Recently ran across this problem.  Needed to fit an exponential growth model to a set of data where the curve must pass/start at the origin. Most of the exponential growth models in Fit Curve don't allow you to constrain the model parameters so that the curve will go through the origin.  So I wasnt' able to do what I needed in Fit Curve.  I was able to do this in Non-linear by building the model I wanted, but that is rather technical and above the level of the typical user who wants to use Fit Curve.  Many chemical and physical kinetic processes y(t) start with y(0)=0.  Currently only Weibull Growth &  One Compartmental Oral Dose have that property.
Could either:
a) Allow for fixing and constraining parameters in Fit Curve so that you could get y(0)=0, or
b) Adding exponential growth models that go through the origin.  For example, these models would be nice to have
y(t) = a(1-exp(-bt))
y(t) = a(1-exp(-bt)) + c(1-exp(-dt))
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
