New Formula column/ Distributional: "Normalize"
☐cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
Please add a function "normalize" to the right click/New Formula Column/Distributional menu which calculates robust values by
:myColumn_norm = :myColumn / Col Median(:myColumn)
9 Comments
Sarah-Sylvestre
Level V
@hogi - Thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
Status changed to: New
Hi Holger, thank you for this request (and the many others). Having a robust normalization option might make sense, but we haven't seen other such requests. Have you considered creating an add-in for this and other functions that you frequently perform?
hogi
Level XIII
Hi @mia_stephens.
"sorry" for the many requests :)
You are right, for some of the topics (like the normalize) I already have a shortcut on my toolbar - I like the idea of "staying in the flow" as much as Steve does:
https://community.jmp.com/t5/Discovery-Summit-Americas-2022/Stay-in-the-Flow-With-Custom-Scripts-and...
So, why the "wishes"?
I am a bit surprised that nobody missed the "normalize" yet.
But I am sure that once it's there many people will use it.
It's like with the zipper.
For many thousands of years, nobody missed it. But if nowadays zippers were not available anymore - for sure: people would notice.
jthi
I have made following suggestion some time agoAdd normalization and robust statistical functions (and matrix functions) .
Also I would like to comment on the creation of add-in / other function. Big issue with those is distribution (and responsibility). There are many great add-ins even in JMP Community which in my opinion should be default features in JMP.
Sarah-Sylvestre
Level V
hogi
Level XIII
I implemented a very versatile normalization function in the QuickSelect Add-In.
https://community.jmp.com/t5/JMP-Add-Ins/QuickSelect-Toolbar/ta-p/566965
If you want to implement a normalization function in the official version, you could steal some ideas from there :)
hogi
Level XIII
Normalize GUI was moved to a separate AddIn: Normalization GUI .
hogi
Level XIII
@Sarah-Sylvestre
with Normalization GUI  available via the community:
very low prio -> can be closed
hogi
Level XIII
please keep the wish open for votes.
A severe disadvantage of the AddIn compared to an entry in the new formula column menu:
It is not available in reports to generate transform column : (
please have a look at the Custom Binning Framework in JMP.
It started as a small Addin provided by @Jeff_Perkinson :
 https://community.jmp.com/t5/JMP-Add-Ins/Interactive-Binning/ta-p/22434
Just when it got implemented into the new formula column menu, it got superpowers:
Not by new functionality, just by the fact that it is available in every report - to generate the column the customer needs.
OK, cool: One can even edit the binning afterwards -  maybe also worth to consider for the Normalization?
surprisingly: doesn't work for transform columns which are generated in a report.
