New Formula Column - new option: just calculate
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
The New Formula column submenu in the column right click context menu is very useful to quickly generate new formula columns.
But: Often a user just wants to get a column with the values, without the need of a formula column.
compare the options of Recode:
Please add an option to the New Formula right click context menu, allowing the user to toggle between
- Formula Column and
- New Column (just calculate).
A third option could be:
- Formula Column (1x) like it is implemented in the Normalize Function of the QuickSelect Toolbar  :
This way a Formula Column is added to the table, but the evaluation is disabled after a first calculation.
Why is this idea important?
With the additional option available, a user can generate "pre-calculated" columns as easy as he can generate formula culumns.
The third option would allow the user to generate a pre-calculated (non updating column) with the additional benefit that the calculation is stored/freezed - ideal for documentation, and with the possibility to reactivate it.
8 Comments
jthi
Evaluate Once option should in my opinion be added to jsl and maybe even the non-formula version. We already have it with << Set Each Value but most of the people have no idea that it should be used instead of formula if you have no need for formula
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Big Class.jmp");
// "New Column" already exists with jsl
new_col1 = dt << New Column("X", Numeric, Continuous, << Set Each Value(:height*:weight));
// Evaluate once kinda does, but it requires few commands
new_col2 = dt << New Column("X", Numeric, Continuous, Formula(:height*:weight));
new_col2 << Suppress Eval(1);
// Formula isn't evaluated
new_col3 = dt << New Column("X", Numeric, Continuous, Formula(:height*:weight), << Suppress Eval(1));
// won't get reference
new_col4 = (dt << New Column("X", Numeric, Continuous, Formula(:height*:weight))) << Suppress Eval(1);
show(new_col1,new_col2,new_col3,new_col4);
hogi
Level XIII
Hi @jthi - thank you for supporting this wish  :)
I feared that one even has to put some
wait()
between the column generation and the
Suppress Eval(1)
If the calculation takes too long, the suppress Eval could interrupt it?
But doesn't seem so - I also checked for larger tables.
Nevertheless, would be nice to have the one-time-eval available :)
jthi
When waiting for formulas to evaluate you shouldn't trust wait and it is almost always better to use <<Run Formulas (it should evaluate all pending formulas).
jthi
This option is "already offered" in Formula Editor. If you go to top right corner and select Suppress Eval:
and then you press OK/Apply you are given these options:
Captured action seems to only have Suppress Eval
Data Table("Subset of Big Class") << New Column("Column 6",
	Numeric,
	"Continuous",
	Format("Best", 12),
	Formula(:height * :weight),
	Suppress Eval
hogi
Level XIII
With "this option" you refer to ...?
Sarah-Sylvestre
Level V
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
Hi @Sarah-Sylvestre .
This wish can be archived.
With JMP18 the bug with Excluded() in column formula was fixed.
SO: no need anymore for 1x evaluation.
Sarah-Sylvestre
Level V
Status changed to: Archived
